If you misplace your power supply and you're near a Radio Shack you can purchase one of their off the shelf supplies. The Mopho Keyboard and Mopho Desktop will operate on a DC voltage range from 13-15 volts DC. The Mopho Keyboard needs a minimum of 400 mAh, while the Mopho Desktop requires a minimum of 220 mAh. Any power supply that provides a DC voltage between 13-15 volts and 400 mAh (Keyboard), 220 mAh (Desktop) or more will work.
Here are the Radio Shack PSU specs:
Radio Shack Power Supply
Enercell™ 15V/1000mA AC Adapter
Model: 273-332 | Catalog #: 273-332
$29.99
Enercell™ Adaptaplug™ M
Model: Adaptaplug M | Catalog #: 273-344
$6.99
PSU plug specs: OD 5.5mm, ID 2.1mm, length 9.5mm
