Power supply alternative from Radio Shack 28 April 2022 15:11 If you misplace your power supply and you're near a Radio Shack you can purchase one of their off the shelf supplies. The Mopho Keyboard and Mopho Desktop will operate on a DC voltage range from 13-15 volts DC. The Mopho Keyboard needs a minimum of 400 mAh, while the Mopho Desktop requires a minimum of 220 mAh. Any power supply that provides a DC voltage between 13-15 volts and 400 mAh (Keyboard), 220 mAh (Desktop) or more will work. Here are the Radio Shack PSU specs: Radio Shack Power Supply Enercell™ 15V/1000mA AC Adapter Model: 273-332 | Catalog #: 273-332 $29.99 Enercell™ Adaptaplug™ M Model: Adaptaplug M | Catalog #: 273-344 $6.99 PSU plug specs: OD 5.5mm, ID 2.1mm, length 9.5mm Related articles Power supply alternative from Radio Shack Analog Synths and Expected Variations Pulse width 0-1 or 98-99 no sound? Mopho Audio Input explained
